TwinTurbo.NET: Nissan 300ZX forum - Re: See if voltage is at each injector. Disconnect the >>>>>>
Subject Re: See if voltage is at each injector. Disconnect the >>>>>>
Posted by cm1wrx on October 09, 2022 at 12:59 PM
  This message has been viewed 182 times.
In Reply To See if voltage is at each injector. Disconnect the >>>>>> posted by ZUL8TR on October 07, 2022 at 04:54 AM
Message Ok, i was able to verify voltage at each injector. I get around 12.1-4volts (same as battery) on one side of the connector. Think I mentioned before but I also did a continuity check from the ecu to the injectors as well just to verify. I am totally at a loss. My only assumption right now is that the ECU is not grounding the injectors. Any thoughts on how to verify this?
